Hard Starting as of Late
Hey Gang!
Over the past several weeks to a month, I've noticed my S-Type 4.2 does not start in the normal time frame of the key rotation. I mean it would start right up when the key hit it's stop limit. It has been cranking on a little more before it starts. The other day, after sitting for only a few days, it would not start at all.....just cranked and cranked. I stopped several times and the last time I let it sit for about 20 seconds and tried it again, it started right up. Drove it a few miles and parked it about 15minutes and then it started right up as usual.
Does this sound like a fuel pressure issue? Fuel pump going? Fuel Filter clogged up? Any thoughts? Unfortunately I lost my job so I don't drive it every day like I used to so is that maybe the issue? As always thanks for your thoughts.
Received 2,654 Likes
First thing to check is the battery voltage. With the ignition in the OFF position for at least ten minutes, there should be a minimum of 12.6 volts across the battery terminals. If not, try charging the battery overnight and retest it the next day. If the voltage is still lower than 12.6 volts, the battery must be replaced.
Fuel pressure should be between 3 and 5 bar depending on throttle position.
talashek
11-07-2015 10:40 AM
