Has anyone managed to fit a 17" wheel on the back of the STR?
My traction problems were pretty bad at the track the other day.
These problems are only going to get worse as the hp of my STR goes up. I am planning a two pronged approach.
First I am going to fit a set of drag radials to the back of my car. Something like the M/T et street, which they do make in limited 18" sizes, but I would prefer a smaller wheel to give me more side wall on the tires. I fully realize that the car will look retarded with 18's up front and 17's in back. This will be a drag track only thing.
Second I am going to have an LSD rear installed. Usually I do all my own work but when it comes down to doing gear changes, they need to be perfect. I have a friend that is very good at setting up rear ends.
Be careful you can't change the ratio in the diff, the transmission will go nuts...
https://www.jaguarforums.com/forum/g...99/#post553777
As I understand it 17" will fit on the back, but not the front...but that's only secondhand information.
Mclovin22 (11-25-2023)
I happen to have a 17x8 wheel to test fit at the house that is also 5x108 from my Volvo. I'm going to test it and see how the clearance is with both the main caliper and epb.
I have no interest in changing out the diff ratio at this point. This is a street car most of the time, and I like the tall 6th gear to cruise in. I don't even know if changing the diff ratio would help as this might add another shift into the 1/4 mile.
FS[NorthEast]: Jaguar XKR Wheels for Sale
Griffbritgreen
07-27-2016 05:43 AM
Fraser Mitchell
10-01-2015 04:06 AM
