Have an issue with DSC Fault and a tranny issue.
I have a 2003 S-Type and I have no faults when starting the car, but when I start to drive it and use the break pedal for a few seconds the DSC fault triggers and doesn't go away. Happens every time I drive it. Figured I would ask to see if maybe someone else had the issue and could tell me where to start looking. Also the tranny shifts fine is all gears accept between 3-4th where I hear a little rub noise between shifting. Any help would be appreciated.
Welcome to the forum MilitaryMan33,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Jumpin' Jag Flash (08-13-2014)
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
I too recently had DSC code. It was related to a bad ABS speed sensor.
Replacement of the hub assembly (hub, bearing & speed sensor) @ approx $200 plus labor was the cure. Not saying this is your problem, but it's a definite possibility, and not that expensive to fix, esp if you can buy the part from RockAuto and then do the labor yourself. I was not able to do either at the time.
Yea, I had a tranny leak from the plastic pan warping and after I got that fixed is when it kind of started. Maybe they put in the wrong fluid or something. Had a bunch of issues with gearbox faults and being stuck in 4th gear because of the fluid level when I started having issues. I will definitely check out the ABS sensors, I have a code reader, but its not the professional one so I'm not sure if I will get the errors I'm looking for. But I will update as I know more to possibly help others in the future when I figure it out. Thanks for the responses.
