Head Gasket?
Head Gasket?
i just noticed today on my way home that my car was shaking a little bit shortly after that my check engine light flashed a few times then stopped. when i got home and got out i noticed a sweet smell. i noticed no smoke but i could hear a kind of gurgle sound in the exhaust. what could possibly be my problem?
+1 Jag V8 - Flashing engine light equals a misfiring cylinder or multiple mis firing cylinders. That would clearly explain the shaking you felt. When the engine light flashes the misfire detection is readily apparent.
You need to get an OBDII reader to see which cyilinder(s) are affected. The code you should look for is: P030X - X standing for the cylinder...1, 2, 8, etc
That will give you a starting point. Coils are highly suspect to firing intermitently when they are on their way out. It's not that the coil won't fire but it's the duration of the arc that fails, causing the misfire.
Finally, if it is a coil related issue - get a good quality replacement coil, not those cheap ones on Ebay. Good Luck.
definitely not a coolant smell, just dealt with that issue 6 months ago. my first thought was also misfire but 3 months ago i replaced all the plugs and 2 coils because it was misfiring. it shook a lot more when it was misfiring. it could still be that but the smell was something ive smelled before when a friends head gasket blew out. but im wondering if it could possibly be the catalytic converter as well, do they give off a funky sweet smell?
X308XJR
05-20-2019 06:50 PM
Woznaldo
09-26-2015 11:02 AM
