Head gasket job cost for 2003 V8 S-type?
Hello,
I just found out that the series of cooling system issues that I have been having on the S-type that I just got is caused by exhaust gases getting into the cooling system. The system stays pressurized for hours after driving the car, also. My independent mechanic, a Jaguar Master Technician, just ran a test for exhaust gasses in the coolant, and found a lot. He works at a shop with a guy I have been going to for years, who never make things up or exaggerate them, so I have to believe them.
Any idea what the range is for this job? Dealer vs independent. I hear it is a fairly hard job on the s-type due to the lack of room to work. (US dollars)
I am going to try to get the car dealer where I bought it to foot the bill. They said they 'stood behind' the car. I am hopeful that is true. But, I should be prepared for the worst. At least I will have an excuse to put the metal timing chain tensioners in.
Received 6,307 Likes
Hello,
Where 'bouts in Calif. is you ?? North..South..East ..West..
What dealer if I may ask ?? Just curious..
When I got the car, the coolant level kept going down and it took too long to heat up. Found no thermostat. Put one in and it started blowing hoses. Fixed that it started bubbling gasses and coolant out when I turned it off, so the level went down. No leaks. Finally mechanic ran an exhaust gas twice, once with fresh coolant.
I'm in Santa Barbara, bought the car out of town from a small dealer who says he stands behind his cars, and has so far, so I will give him a chance to fix it in his shop.
It is possible that he didn't know about the problem. It is rare.
That sure sounds like it was overheating a bunch. Then they took out the thermostat to hide the problem and then traded it in and dumped the problem. I would now be VERY suspicious of the car. Check every detail while this car lot still stands behind it.
Also good luck with such a dealer because it usually does not end well. Even with a real warranty it's sometimes hard to get the dealer to fix stuff.
Dealer to fix the problem
Good news. I talked to the dealer/owner, calmly explained the problem, the steps taken, tests and syptoms, and he said that they will fix it. Taking it in Saturday.
It is a small town, he's been there since the 80's and he has a brisk buisiness. Maybe this is why- he stands behind the cars he sells.
He apologised and said that head gasket failures are rare on these cars, it was a consignment sale, and he had no idea it was bad.
Seems like an honest guy. I wonder what his favorite drink is , should get him a bottle!
3jagfamily
10-01-2015 01:49 AM
