head gasket replacement!:(
Did this last year
first you will need the front cover gasket, valve cover gaskets.........hopefully you will find a kit on ebay........I paid 455 for a complete gasket kit.........I would replace the head bolts with new ones......the heads were 700 to be rebuilt for both......new water pump, tensioner and idler pulleys........thermostat if you are there would be good........check all hoses and replace them as needed.....check the chains and tensioner (I replaced all of them since I was there).....camshaft sensors are cheap so I replaced those also.....check engine mounts for leaks.......ac compressor health.........
I think I ended up spending a little over 2000 with everything.......plus my labor.....
Just take it easy
Ah yes forgot to tell you that since you have to remove the radiator might as well do the tranny pan and some fresh fluid and sleeve!.....fuel filter replacement maybe?
the car ran fine other than adding coolant weekly. I stop at light then car died. Wouldnt start till i held down throttle. When it started it had small tick n was jerking at stop. then i got it to a parking lot a block away then it died.was bubbling out water then sucking it back in an had oil smoking from back of motor ( i saw a small splatter on firewall).i changed the spark plugs there was oil n there from maybe valve cover leak?but after i changed the plugs it started and idled on its own still with the tick and jerking when slowing to stop. i had It towed to shop mechanic said the ignition coils were good timming chain seemd in time. Did a compression test and 3 out of 4 cylinder had no compression. (What He said) . That He didnt know what the prob was he would have to go deeper in the motor to find out.
KarimPA
09-03-2015 07:32 PM
