headlamp repair
You should be able to spread some of the original sealant towards the rear part of the headlamp. It's also evident in the crevices. Bake them again @ 175 degrees for 5 - 7 minutes and push them back together tightly. As they cool off they will seal. No need for any adhesive. (Thanks Brutal!)
Replacement Adjusters
I didnt know you could get replacement adjusters?? I used the old screw through the front plastic between the lights and that did the trick raising mine back up. I would be interested in repairing mine if I could find the adjusters!!
Where in the world did you locate the replacements!!???
Jaguar S-type S type NORMAL/ XENON headlamp headlight repair kit adjuster 2 SETS | eBay
Adjuster come from Poland
Quality is way better than Hella. They have metal inside with a plastic overlay. Fit perfectly. There are 3 adjusters per side. The screw will not work when all of them are broken. The oven is very easy to use and the adjusters are easily changed. I have mine apart. PM me if you need pics of dissasembled headlight
mikewv100
mikewv100
mikewv100
mikewv100
Thanks, Glyn
Woznaldo
09-26-2015 11:02 AM
