Headlight Adjuster Repair Tutorial
Hi
I wanted to let everyone know that I created a tutorial on the installation of X-Type and S-Type headlight adjusters. I get at least one contact per week asking how to put the parts in so I did the best I could.
It is just the parts instillation, I think there is plenty of info on getting the lights out of the car and separating the lens from the bucket.
The images are using the S-Type Headlamp but the procedure is the same for the X-Type.
Installing x-type and s-type headlight adjusters
Joe
Joe
The following 2 users liked this post by Joe Cee:
Jumpin' Jag Flash (07-18-2013),
Tijoe (07-17-2013)
Great web site!
I know you stated that there was plenty of posting on how to take the lens off, but if you could add a page that describes and shows how to get the lens off, that would really help out the novice or first timer. I found that removing the lens was the worst part of the process. You either need to put the complete assembly in an oven and heat it up until the sealant softens, or use a hair dryer to soften the sealant it as you gradually remove the lens.
I also found that my original white plastic parts were completely rotten and the plastic shattered into little pieces/powder as I removed the old broken parts. (Really poor choice of plastic material by Jaguar?)
In the headlight assembly I repaired, I removed all the sealant and installed new sealing tape/adhesive.
I purchased mine from a company called Filmtools:
CRL Black Butyl setting tape/adhesive CRL1303. Worked great!
I purchased my repair kit from E-bay.
Thanks. You described the process pretty well, l should just paste your thread on there
. I'll try to put some more things on there, it takes me a while to get it right because website design is not something I do every day. I replaced the butyl rubber also but it is probably unnecessary in most cases and it is a real pain to clean the old stuff out.
Joe
Joe
Great web site!
