Headlight Question:
Headlight Question:
Ok so I have seen where you guys have posted on fixing drooping headlights on here. But the thing that just started happening to my 07 STR tonight is the driver headlight is aiming straight down. Like it's not auto leveling itself like the passenger side is. Start the car, turn lights on, they both used to lower then raise to the position but now only the passenger side is moving. Think it could be a bad wire or is the motor smoked in the headlight?
Sounds exactly like the same problem that Brutal described. Check here:
https://www.jaguarforums.com/forum/s...ype-faq-10745/
Fletch44
09-28-2015 02:21 PM
