Headlights, turn signals, fog lamps not working...
This is a pre-purchase question regarding a 2005 S-type 3.0 I would like to buy. I have not been able to find any similar forum threads on this subject. So, I'm hoping someone can offer some help and insight.
From what I've been able to garner by browsing the forum, S-types have "modules" that seem to control related functions of the car's operations. The headlights, turn signals and parking or fog lights do NOT work. Essentially, none of the lights in the front of the car work. However, all the lights in the back of the car are OK. And, none of the functions of the car's windshield wipers work either. But, everything else electric works fine.
Is there a bad module in this car that if replaced would have all or most of these parts working? If this is the case, what's the "ballpark" dollar amount for doing so if a mechanic does it (unfortunately, I'm not a DIY-er)?
If a module replacement is not the solution, what else might be wrong? I can get this car at a pretty good price, so it may very well be worth it to buy and fix.
All modern cars have them. Some a lot, some just a few.
The Electrical Guides are on JagRepair.com - Jaguar Repair Information Resource and you'll need them if you get the car. You can think your way around them. (And if you don't fancy that , consider not getting the car. But it's not that hard to do if you spend some mental effort.)
AzRon (02-06-2016)
Received 6,320 Likes
If I understand you correctly, fixing this is not a "slam dunk" for even an experienced Jaguar mechanic. And, it's a problem with a cause that can not be pinpointed easily. So, successfully diagnosing it might require quite a bit of time which could get very expensive. On the other hand, if I put some brain power into it, it's conceivable that I could figure it out. Am I getting this right?
AzRon (02-06-2016)
I'm finding that referencing the info that's on JagRepairs.com to be a bit overwhelming. I've spent considerable time going through what seems to be the sections of the site that are most pertinent to my issues. And, while I'm accumulating plenty of exposure to Jaguar engineering, I can't say I'm finding what I'm actually looking for... to the degree that it's obvious to me. So, can anybody fine tune my search by hinting at where I will most likely find what I need in the sections below...
Electrical
Circuit Testing
Jaguar Electrical Systems I #600
Jaguar Electrical Systems Introduction #601
Jaguar Electrical Supplementary Restraint Systems Introduction #620 3_04
Jaguar Electrical Advanced Electrical #680
Jaguar Advanced Electrical Systems Revision #682
Jaguar Electrical Systems Multiplexing Systems #684
Jaguar Advanced Electrical Systems & Diagnostics 1997 - 2008 #688
Jaguar Advance Diagnostics Multiplex Electrical Systems MY 1998
Jaguar Multiplex Advanced Diagnostics MY 2002
Electrical
Circuit Testing
If you understand electrical and electronic basics (volts, ohms, amps, relays, how to use a meter, etc) then I'd start with the Electrical Guide and skip all of those you posted.
If you don't understand the basics then it's going to be a biggish task (but I thought simple stuff was taught at school).
AzRon (02-08-2016)
Received 1,442 Likes
Hi Ron and greetings from the far side in Australia,
I try to be a glass half full kinda person, but with your limited skills and need to rely solely on full price professionals to maintain your car, then IMHO, this does not sound a wise purchase. Sure, it may be a simple fix - but in that case, surely the seller would have done so?
I'm certainly not saying don't touch Jaguars, but if you are not well equipped to tackle tasks like this, then sensibly, go for a standard of presentation and history of proven, documented maintenance that minimizes such problems.
I hope my 2c doesn't offend and I admire your spirit. It's not so much that the learning curve is impossibly steep, but it is relentless and very tough without those basics. Fault finding from a schematic is a tough skill to learn by "correspondence". If you are determined, find a retired or semi-retired pro; get him to teach you; then buy the suds to sit, yarn and say thanks.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Ken
Ken
AzRon (02-17-2016)
Yes. As a general rule any lighting on the front of the car is controlled by the FEM (Front Electronics Module). In the rear it's controlled by the REM (Rear Electronics Module). Now these need to be programmed for your car so you can't just swap them out.
So I think your problems points to the FEM. But you need to do more trouble shooting because it could be something else.
If you want to study it I would get the free JTIS on this forum and look for FEM trouble shooting. If not take it in and hope.
It could be something as simple as a bad turn signal stalk too. Have you monkeyed with that any? Try flipping it every which way. If you see any changes then I would swap the turn signal switch before I did anything else.
AzRon (02-17-2016)
stingray71
01-15-2016 02:07 PM
