heater queston
heater queston
The 2005 purchased on Monday had great air conditioning, just serviced, Forgot to check for heat. Well yesterday it was about 40 degrees out, put the heat on, no heat. The water valve for the heater core was leaking, so replaced it, lot s of heat now. Problem is now the heat keeps coming out, & wont stop, drivers side more than passengers, when the heat is turned down, the air conditioner can not over come the heat. The only way to stop blowing hot air is turn the blower off. What is the most likely issue causing this problem?????Seems like the flap to the heat might not be shutting, so the heat keeps on & the air can not over come it putting out heat all the time.
Long-winded troubleshooting guide for you here:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Specifically, run the tests in post #2 to check the operation of your new DCCV. Don't change any other parts until you verify that. Maybe you'll get lucky and the problem is as simple as a blown fuse. Without power, the DCCV defaults to full hot for safety to make sure the defroster will work.
The guide also has a link to check the control module for damage sometimes found on 2003+ cars.
Received 2,650 Likes
If you search this forum, you will see this topic has been covered many times:
https://www.jaguarforums.com/forum/s...003-faq-36719/
Either way, your symptoms changed dramatically for the worse after the replacement. Run the tests in that troubleshooting guide to be sure. For the moment, ignore your previous conditions. Base your troubleshooting on the current symptoms after the replacement.
If it comes down to another DCCV, don't get another from the same vendor. Could be you'd get another one from the same bad batch. I've had that happen with other parts, although not a DCCV. Talk about a troubleshooting nightmare!
As far as the modules, the typical damage can be repaired. More details at the previous links.
Problem appears to be handled, at least for now. Had a burnt spot in the trace as was predicted. Bridged the burnt area only, leaving part of the original trace, at both ends, as a safety factor. A dab of gorilla glue to protect the repair from vibration, put it back together with the desired results.
aholbro1 (11-07-2017)
