Heater Valve Replaced...Now This
I think you have a different valve than what is fitted on the 2003 and sub, possibly a different module, as well. But to the extent there is any commonality, I had the same symptoms as you are reporting and John is correct, a module trace was burned:
https://www.jaguarforums.com/forum/s...-other-126824/
They are not too expensive if you look around. This link shows the effort of disassembling the DCCV. JagRepair.com - Jaguar Repair Information Resource
Even though he pulled it down to see why it failed. A new part was used to replace the old one.
Part Number: 2000-2002 JAGUAR S-Type Heater Control Water Valve NEW XR8 22975
Link for the part $68 from PartsGeek.
Jaguar S Type Heater Valve - Heater Control Valve - Bosch Motorcraft - 2000 2001 2003 2005 2002 2004 2006 2007 00 01 03 05 02 04 06 07 - PartsGeek.com
http://www.jagrepair.com/images/Auto...%20Removal.pdf
I bought my DCCV from Amazon it did not work. It was not a genuine Jaguar part.
I believe the Lincoln part fits: Motorcraft YG355 Heater Valve. But not necessarily cheaper.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
