Heating Problem
#41
#43
Received 2,192 Likes
#44
#45
I'm interested to see what happens with the new valve, since I'm having some issues with my 2002 S type. Mine is blowing cold air when the car is parked or at stoplights, then warm when moving. I haven't even looked under the hood for anything yet, just starting to search the forum for clues.
#47
Well those who suggested the low collant were correct. I had the oil changed yesterday and topped up the coolant, and this morning the heat is working correctly. So I guess it means I'm now a member of the busted overflow tank club. When it gets light out, I'll take a peak under the hood and see if I can find where it's leaking.
#48
Cheers,
#49
Gus - easy fix: sell your old cars & buy new ones
(kinda expensive but hey)
#51
Gus (12-20-2011)
#52
#53
#54
Posted on other site as well
Gus,
I found this info.
Heater core
The heater core consists of fins and tubes arranged to extract heat from the engine coolant and transfer it to the air passing through the heater core. The heater core is separated into two sections. Air passing through one section is directed to the driver side of the vehicle, while air passing through the other section is directed to the passenger side of the vehicle. The heater core has separate inlet ports with a common outlet port.
Dual coolant control valve
The dual coolant valve regulates the flow of engine coolant to each half of the heater core. Two electric solenoids, Which are individually actuated by the heater control module, are the control elements. The valve contains three ports: inlet port - coolant from the engine outlet port - coolant to driver side of heater core outlet port - coolant to passenger side of heater core
Auxiliary coolant flow pump
Vehicles fitted with 4.2L engine
The auxiliary coolant flow pump is electrically driven and provides increased coolant flow during low engine speed operation. The pump is also used to circulate coolant after the engine is turned off under certain conditions.
So it could be a number of things I seem to remember that you have checked the DCCV, if not unplug it should default to heat, then check that the electrical soleniods operate individually, or the heater matrix, PIA, so my first choice would be to change the DCCV for a known good one
Gus,
I found this info.
Heater core
Gus (12-21-2011)
#57
#60
Thanks, i added anti-freeze n the heater worked normal, but a taxi collided with me when i was going back home from autozone
