Hello everyone New to the Forum Question About Brakes???
Guest
Posts: n/a
Hello Everyone I just purchased a used Type X and need to change the brakes. If so how difficult is this change? Does the Type X have normal brakes or is the brake change complicated like in the E320?? also is there is a link with instructions I would appreciate it greatly. thanks.
Brakes on the jag are very easy. Basic for the front disk....2 bolts, remove caliper, open bleeder valve and press pistion back into cup. Close bleeder vavle.
Rear disks require the special tool to compress and rotate pistion back into cup, same procedure, open bleeder valve, press and rotate pistion back into cup.
Top off with fresh brake fluid and bleed brakes.
Should take approx 1 hr .
