Hello Jagz, AC /Air condition recharging port
The high-pressure service gauge port valve is located on the tube assembly, condenser to thermostatic expansion valve.
The low pressure service gauge port valve is located on the manifold and tube assembly at the compressor.
If the compressor is being replaced, the desiccant bag must also be replaced and the correct amount of refrigerant added by weight to a maximum of 750 grammes.
I've moved your question from General Tech Help to S-Type forum. This is the place to post technical questions about your model.
I replied to an earlier question of yours about sensor location but have no idea if it helped or if you have even seen it......?
FS[UnitedKingdom]: 2003 X Type 3.0 V6 - £1300
richamgblack
04-13-2017 04:32 AM
FS[Central US]: X-Type 3.0 Engine
91stealthes
11-08-2016 12:01 AM
MHrusovsky
07-08-2009 04:54 PM
marklegend
12-22-2008 09:51 PM
