Help!
Help!
I keep getting these 4 codes popping on my 05 S-type 3.0 every time I use my code read and I have tried to fix every little problem that may seem to be associated with them. The codes are p0395 (cylinder 5 misfire) not to long ago I replaced all my ignition coils and spark plugs *** regular maintenance and the fuel injector was not good so i changed it and went ahead and changed all the o-rings to the other injectors to be sure there is no leak , still no luck. P1313 I'm guessing is being caused by the supposed misfire. P1316 injector circuit/I'm codes. And p1646 auxiliary input /output. I have changed the upper air valves at the rear of the intake manifold and both the pig tail connections to both of them. The car does not idle bad when I first crank it once the car stops moving and I make a stop some where, when I feel the motor have a slight share to it. So I'm almost out of ideas as on what it could be I have read other forums about what it may be but I would like some more insight on my specific little problems. Im trying not to give up on it
Have you replaced the two Intake Manifold Tuner Valve O-rings that are on these 3.0 engines? If not, that should be your next step. The original factory IMT O-rings are yellow in color and are prone to break down and leak, causing misfires and rough running. The new-and-improved IMT O-rings are green in color, are thicker and just plain better, and fix these misfire problems immediately upon installation. I believe these IMT O-rings are still a dealer-only item but they are relatively cheap and are a must-do for any 3.0 engine that has not already had this done. The Jaguar part number for the IMT O-ring is C2S40669. You will need two of them....
I replaced them in my 2005 S-Type 3.0 in January 2010 and have not had a misfire code thrown since....
Where did you look up the code meanings? You might like to use the Jaguar info that's a free download.
P1646 is a bad O2 sensor (or possibly its wiring etc).
Did you really mean P0395?
It won't be "supposedly" a misfire. It's definite. And you are starting to damage at least one of the cat convs.
trucknetjack
12-03-2016 09:49 AM
