help
help
sorry yes it tries to cut out when it is at idle the car some times cuts out but will restart with no problem and it drives ok, also sometime's it will idle at 1500/2000 rpm i have serviced the car fitted new inlet manifold gaskets, plugs filters but no change. i have noticed a hissing sound coming from the throttle body assembly on the inlet manifold is this normal? thanks
hissing = air leak
there should be no air leaks!
If you have a decent OBD tool, you may find either or both of:
1. it's not running CL (closed loop)
2. fuel trims (especially at idle) are well away from 0%, showing fuel being added to compensate for the extra O2 (oxygen i.e. air)
(note: unless CL, fuel trims are not meaningful and usually show as 0)
Some like to use a little propane to confirm it but if you can HEAR it then it's quite a BAD leak!
The extra revs are probably it going OL (open loop) but it will just stop doing it if you fix the leak.
If you had a vacuum leak, it would most likely have a p0171 or p0174 (or both) code stored. Same goes for a throttle fault....there would be a code, and MIL. You say you have no warning lamps or codes.
I'd put a fuel pressure gauge on it and attempt to duplicate the issue. See what FP does when the fault occurs. Just to rule out the simple stuff.
