Help!!
Help!!
I started my 2005 S-type (3.0 V6) this morning and the check engine light and restricted performance light are on. pulled codes with reader and got:
P0327
P0322
P2135
P1111
I recently replaced the battery due to DSC, Park brake fault issues. solved those problems, now it is doing this.
Could this still be the battery? Could this be a moisture problem? Car was running fine until today. By the way it has been sittng out in the rain for two days.
What do I do now??????
P0327
P0322
P2135
P1111
P0327 Knock sensor
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P2135 Throttle/Pedal Position Sensor/Switch "A"/"B" Voltage Correlation
What gas do you run? And I would point to a moisture problem for the TB. Check the voltage on the battery both with the car off and with it running.
