HELP Air Bag light on
I need some help I have my Air Bag light on the dash come on and stay on. Some time it will stay off. This all started happing after my friend was using my car.He said he was smoking acigarette and it fall under the drive seat, he got cigarette out and he pored some water under the driver seat to make sure it was out. Now my Air Bag light go's on/off some times. Is this something that can happen because of the water? I can’t pull and codes with the reader's that I can use.
What reader's do guy's use on the forum?
Water under the seat...that's my guess. The module or harness got compromised. i'd let it air out for a week or two, perhaps unplug the module to facilitate quicker drying, then plug it in later and give it a trial run for awhile. And don't let your buddy smoke in your car. Obviously hazardous to his lungs and your car.
Ken Dreger (04-28-2024)
Received 2,193 Likes
first, quit hanging around morons
second, the air bag wiring has seperate wiring that doesnt go through the seat module, the SRS connector is yellow and common on this car to break off at the connector under the seat from moving fore and aft. move the seat all the way up and forward, and inspect the connector from the rear. if no visable signs of damage, get codes pulled, it should be giving you flash codes when you first start before it goes solid. next most common thing is steering wheel cancellation module behind steering wheel
OBD II scanner. You have to remember your seat has a side airbag which is on the same circuit as your steering wheels airbag. I read on a different forum how something similiar to your situation happened in an Infinit I30. Can not find the link though. Anyways air out the module like h20boy says.
ORIGINAL: BRUTAL
Ok I was looking for the yellow srs connector I can’t find it.I cant really see any wires.I tried to pull codes with a reader but nothing. As for the flash codes it is of at this time so I can’t read them, how am I to count the flashes is it 2 or 3 number code or.. I think I am going to pull the driver seat out, is there any thing for me to watch out for. I can unplug all the connector with no problems?
brutal means you need a more advanced scanner to read codes like the ABS and air bag system. 95% of normal owners won't have this ability with their scanners. Make a friend at the dealership and see if they can pull the codes for you. My service guy doesn't charge me to do this from time to time.
I would try BRUTAL's suggestion to move the seat up and back and forward enough so you can reach under the seat to check the airbag sensor connectors. These are notorious for either breaking or coming apart. On my 2005 S-Type I did this and it fixed the problem. I assume your car is still under warranty since it's a 2007 so you may want to check with your service manager for coverage advice. You could also get a scanner as mentioned earlier to debug your problem.
Thanks eds123. I saw your post with regards to the clock spring: https://www.jaguarforums.com/forum/s...87/#post419638
I was going to try and find this "yellow wire connector problem" under the seat first, and then look at the clock spring secondly. The reason I'm going to look at this 2nd is that it's more work, and I'm not convinced that's where my problem exists since all other steering wheel functions are working, i.e. horn, stereo and cruise control functions.
I would hate to pull the steering wheel all apart procure and replace this clockspring and realize it's not there. Which I might not have the choice unless I want to take it to the dealership, and even then, I'm not convinced they wouldn't be doing the same guessing game but at a much higher cost.
Every function on my steering wheel worked correctly as well which is why I was hesitant about pulling the steering wheel. Turned out that was the problem. Never found the Plug under the seat either. If you need a clock spring search eBay by the part number because I found a used one for 1/3rd the price of new and it works great. Don't be nervous about the procedure and take your time. One more thing to add is when you install the clock spring it has directions on the front of it for setting it in the correct position. This way your turn signals work correctly.
