HELP!!!!- JGATE issue
have 05 s-type 3.0 103k. Today driving just fine. Had made a couple of stops. Then I pulled into a parking space and wanted to back up a touch and the car would not come out of park. Something was holding it. Turned car off and back on- still no dice- I pulled a touch harder and something gave way and the shiftier released, but was too easy and would not get into gear. I put it into park and the car would drive in reverse and the only 2 gears that illuminate are P and N. So what has happened- is this the 2 bolts underneath or something that is under the center console. Is there any technique for removing part of the center console and making a manual adjustment to get into some forward gear or am stuck and need to do what to fix it. This all happened out of the blue and I have no such trouble previously.
Tom in Dallas
Tom in Dallas
Tom in Dallas
Tom in Dallas
Under the car.
Check the two 8mm bolts are still attached and tight .
Hopefully the cable did not snap .
There is a possibility of the metal pin that goes into the plastic piece that moves and when I move it to the other side of the gate it looks to slip out of the plastic piece, but then slips right back in-line- so it may be made to do that. Curious if anyone knows.
Just need to take it to a tranny guy down the street and let him use a lift vs me jacking up the car and getting under it. I have seen the TSB and Alldata and frankly the drawings are so vague i cannot make out as to where the plate and bolts are.
Any other ideas or suggestions are indeed welcome.
Tom
Did not need to open the ash tray. I have a plastic splunge for that purpose and it was easy enough to pop off. Have done it several times before just to detail the car.
Tom
That is what I did and moved the plastic piece that slides along the right side until it went into drive. I had to move the shifter over to the 3,4 5 side to do that, but at least I can drive the animal and avoid home type towing or screwing around with a tow truck at all.
Tom
Tom
Problem solved. Took it to a guy with a lift- put the old screw back in and tightened the one there and put on some loctite. Cost was only $25.
The only thing that is different is that without my foot on the brake I can move from park to other gears and and while I get the fast beeping type of sound to tell me that I am out of park, I seemed to remember that it would not physically allow me to move it out of park. What is correct and this happens whether I have the key in or out and the car on or off. It is not a big problem for me- but it is a slight safety feature so what gives and how to repair if it needs to be.
Tom in Plano
Tom in Plano
vdpnyc
10-30-2016 04:10 AM
vdpnyc
10-28-2016 03:53 PM
anindyam
02-22-2016 07:00 AM
