HELP mayday mayday
If you skipped more than one tooth, you may have valve damage.
You could also have non-generic codes that your reader is missing.
Does your reader allow real time monitoring of engine parameters? That may provide some clues, as might a compression test. Also with some driving it may eventually set a code.
It was not clear to me that you were not running. You had said the misfiring was gone, so I assumed it was running.
In any event, whether you have valve damage or not depends on engine design and some element of luck. It is well known on the Jag 4.0 that one tooth skipped will cause rough idle, two or more teeth skipped may cause valve damage.
