Help Me! - Coolant leak
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Ok, so I own a 2005 Jaguar S-Type 3.0 V6, I noticed I have a pretty bad coolant leak, as I disconnected to coolant reservoir, the metal clip the holds the lower hose in place fell somewhere and I cannot find it. What is this metal clip called? Can anybody tell me where to get this metal clip so I can get back on the road?
Welcome to the forum packman09,
I've moved your identical question from Jaguar Forums Advice / Feedback & Suggestion Center and General Tech Help to S-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Hmmmm....not shown on JEPC....probably shouldn't have lost that one! Neither could I find it on Jagbits or Rock Auto. Most likely called a "retainer clip" or some such. Welcome to the forum, and hopefully someone will happen along with the answer...but I've crapped out!
Best bet to find one might be to raid your nearest junkyard for 03 and subsequent S-types, not certain but I believe the same clip is used on the V-8's as well.
If you were disconnecting from above, and didn't pull the undertray, it should be down there somewhere. Try a small shop magnet and trace over all the likely nooks and crannies?
Here are pictures of the hose which attaches to the "coolant reservoir"(expansion tank) and the locking spring clip which is part of it
You probably lost the spring clip.The first 2 pics show the clip postion for removing the hose and in positon to lock the hose.
You would have botch the assembly to use a jubilee clip!Just find a new hose somewhere.
I found the hose whilst looking (unsuccessfully) for the clip. It hadn't occurred to me that a new hose would likely needs include the clip! I believe they are on Jagbits.com. Wherever it was, it was "picture not available" and there was no mention of the clip.
OkieTim
09-08-2015 04:48 PM
