help much needed
help much needed
I have a 03 s type stalled out on me one night n hasn't started since sprayed so 2+2 in the throttle body n started to turn over got a new pump so I thru it in the one on the pass side n still no start I didn't replace the other one on the drive side im guessing that the sending unit I believe not sure tho. so I checked for power at the connectors on both side n have no power getting to the pumps and ideas like a relay sensor maybe broken wire im lost and need to get this back up and running any help I appreciate very much thanks
Norri (03-21-2014)
help much needed
its an 03 non supercharge 3.0L. the battery is low but I put a charge on it a couple time just cause it gets low from cranking so much. I checked all the fuses n relays under the hood I do here the relay click as I turn the key to the on spot. n I checked the fuses near the rf kick panel but ill double check again
The blown fuse may be a one off deal - but if it blows again - this is indicitive of your fuel pump going south...
Charlene n John
09-28-2015 06:01 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
innzane
09-02-2015 10:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
