HELP my A/C blows hot air
Hi everyone OK this is my problem I got a 2003 S-Type R my front left and right and the rear back vents is blowing hot air when I turn on the A/C and the front middle vent is a lil cold but not as cold as it should be. So I took it to a shop after it got the A/C recharge it was doing the same thing so I took it to another shop that work's on Jags they put it on the machine and told me it was the heater valve and auxiliary water pump so I got those change and it still does the same thing. PLEASE HELP me if you had the same problem know what it is
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Guest
Posts: n/a
Have you gotten to the bottom of this? I have the same s-type and same problem. Had the heater control valve replaced and still blowing hot mixed with a/c. A/C recharged already and the dealer is clueless and wants to keep throwing parts at it at significant cost. HELP. I live in Phoenix and no a/c is serious business when it is 110+.
check out this link i tired messing with my car but it didnt do any thing mybe ill fix your problem
http://www.jaguarforum.co.uk/viewtopic.php?t=2600 let me know if you find out what it is
Guest
Posts: n/a
I have a 2003 Lincoln LS which is the Ford DEW version of the S type. I also had changed the heater valve (DCCV) and the thermostat and verified the Aux. coolant pump was working. Still had only sorta cool air. Finally changed the in cabin air temperature sensor. This is the one behind the grill right above the ignition switch. It pretty cheap and not too bad to change. Don't get rough with the plastic dash pieces. The old sensor was crudded up and after replacing it my car has ice cold A/C again.
[/align]
[/align]
keep me posted if you find out the problem because it sucks to drive a Jag on summer time with your window roll down when is over 100 degree.
Follow this procedure to help narrow down the possible source(s) of this problem.
Use a multimeter and take some measurements:
1. Run the engine.
2. Set the controls to max "Lo" for both driver and passenger sides.
3. Confirm that the air is still blowing hot (take note which vents blow).
4. Disconnect the plug from the coolant control valve and take voltage measurements at all 3 contacts in the plug. The middle contact should read 14v or so.
5. Take resistance measurements at the 2 outer contacts in the plug (measure between each contact and a chassis ground). The 2 outer contacts should read close to 0 ohms.
6. Jumper the middle contact in the plug to the middle contact at the valve. Jumper one outer contact in the plug to the corresponding outer contact at the valve using the multimeter to measure current. Be careful that you don't short anything with the middle contact in the plug (it's always hot +12v-14v). Repeat the measurement at the other outer contact after disconnecting the first outer contact (don't disconnect the middle contacts yet). Each measurement should read 0.6 to 1.1amps.
7. With the middle contacts still jumpered between the plug and valve, jumper an outer contact on the valve to a chassis ground, while using the multimeter to measure current. Check to see if any vents blow cooler air during this grounding process. Repeat the measurement at the other outer contact and check the vents again.
8. Reconnect the plug to the valve.
9. Shut off the engine.
10. Report the results.
1. Run the engine.
