Help! My wipers come on and won't turn off!
2002 S-type 4.0L Sport w/ 50 k
It started several weeks ago, on occasion the wipers would come on and not turn off with by moving the stalk. Started happening again this week and now the activate on turning the key and continue wiping, can't turn'em off. Car is garaged, has not been subjected to water, rain or car wash, engine compartment is dry and no water in the cowl.
I have on occasion wiped down the engine comparment and gently moved some wiring but did not uncouple or disconnect anything. Really can't see any wiring or motors related to the wiper motors.
Need help soon as we look silly drivng in the Florida sunshine with the wipers going!
TIA
TIA
Guest
Posts: n/a
I would consider to isolate and pull the fuse for the wipers, so you can drive your car, it sounds like a bad switch.
I had a Towncar, when you turn the wipers off, they would park anywhere on the winshield, it was isolated to a bad wiper motor, but it worked!
Switch with rain sensing wipers is $125-$170 at dealer depending on exact VIN.
I would probably check a little more before saying the switch is bad. Jaguar wipers are notoriously difficult to diagnose, especially if you have rain sensing. A fault with the rain sensor or the rain sense module or wiring at the mirror could cause wipers to stay on even when switch is turned off.
Simple test to exclude switch. Remove 2 or 3 screws that hold lower steering column cowl on. Disconnect wiring from switch. If wipers stay on it's not the switch.
Excellent advice! I do not have rain sensing but I did remove the lower cowl and test plugged and and unplugged. While doing that I noticed that with a little bit of wiggling I could get to the retaining screws for the switch and Voila ... out came the switch without having to remove the steering wheel/airbag.
You were right on the price ... $170 plus tax.
Thanks again for the advice.
David
David
Well, it has been about two months since I replaced the wiper switch and the gremlin has struck again. My wife went to leave for an appointment and when she started the car, dry in the garage, the wipers came on and would not respond to the wiper switch. Strangely enough, they will speed up in the fast position but will not shut off. I had to pull the relay to allow her to leave on time.
Does anyone out there have any idea why the wipers will not shut off? It hacks me off the have this occur again after spending $180.00 (outrageous) for the switch.
How about it techies? Any ideas?
TIA
TIA
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
