Help Please.
Received 2,263 Likes
Ok guys, Firstly I am an american. I now live in england. I have been working on cars since I was about 10. Along time ago.
The 2 main cam chains, (out of 4) are fine with no play. I checked this by removing the oil cap and breather pipe. you can physically 2 of the 4 chains. I am sure that after the oil change happens it will either cure it or point me into a more definate direction. I will keep you guys posted.
Please I can understand your terminology bonnet, hood, boot, trunk etc.. I get it all... I also understand that there is other things that in america, canada etc will all use that are differant in terms.
I honestly dont feel its a major worry... I took it up to (above the speed limit) for a long run and checked and rechecked everything.
The head is not gone, its not even showing signs of problems,
The noise goes away after one or two quick revs after first starting.. ie the oil has dropped.
I agree to get something that might be better and long lasting and will hold. possibly magnetic oil or something like that. anyway I will let you all know soon enough... I am focusing on my bike atm for the up comming motorcycle rallys. the car is hardly used because its just not needed... and apart from it sitting for a long period, its perfect. I have fixed nearly everything wrong with her now.... and this is just a annoying bit left... it might be a blocked pipe or lack of oil.. these are my thoughts.. and YES I will be buying a proper jaguar filter.. if the weight of the oil for the engine doesnt matter too much I am going for a 10/40 weight.. usually good with older cars. Anyway thank you all again. Jon
![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
Just for reference, 10W40 is not on the list of recommended viscosities for your engine. I see no benefit in second guessing an OEM.
To put something to bed (hopefully), I have never heard of an OHC bucket and shim being called either a tappet or a lifter. Not just on a Jag, but on any vehicle. This has nothing to do with US, Canada or the UK. If Jag uses the terminology interchangeably, it's no surprise that this might cause confusion.
Thanks Gus. I was looking at a later year manual. Not sure if the OP could count on his temps always being above 60*F though.
surprised 5 - 30 wow... ok... well I will do more research into that... I found that the jag does not have a proper filter... its some after market one. now I drove the car (honestly a total of 2k) at the most if that to be honest... and I have had the car for over a year now. I just dont need a car but I do...
anyway I am looking into this oil and which one will suite best... but you guys on here have been AWESOME for advice... and I cant thank you enough.. one problem after another gets cleared.... and sorted.. and for this I thank you all.
on a seperate note... Does anyone know what clue/adhesive to use for the bottom of the front window?? my rubber has come off in one corner about 14 inches... so I want to sort that out asap... I know its nothing major but I do want to fix it. Thanks.
PS I owe alot of people on here some serious beer!
#30
#31
#32
#33
I use Synthetic (Mobil 1) in my cars and in my 2000 S-Type if I recall correctly around 6 to 7qts with filter and I think that equals 6 to 6.6 liters. Check the fluid level as you go along is the best advice I can offer.
Link http://www.jagrepair.com/images/Auto...sb_09_2003.pdf Page 34
#34
Use it if it makes you feel better.
#37
