Help please new guy
HI GUYS I USED TO HANG ON THE XJ-40s FORUM! SO IM NOT THAT NEW...
Anyways, tomorrow i will be picking up one of my dream cars which is a s-type i have been wanting one for ever but i have read the craziest stories and bad reviews.
so the cat im picking up is far from perfect but a great price IMO, $1,000. it is 2001 v6 has a 120k but it needs a catalytic converter, top engine seal and engine sensor.
inside and outside looks mint
so my questions are: is it worth trying to fix? how hard would it b to fix the seal? i will have someone install the cat converter.
thanks and im looking fwd to add this car to my driveway
Received 2,263 Likes
Sure its worth the fix!
If the following has not been done, I would replace:
Spark Plugs
Coils
Upper Plenum (Intake) Seals
Lower Intake Gaskets
Rubber Elbow under Lower Intake
IMT O rings
Cabin Filter
Fuel Filter
Air Filter
Clean MAF Sensor
*Replace all PVC vacuum lines
The above parts should run no more than $400.00. Since it is your "dream" I would make it right the first time. And what the hell, a nice "dream vehicle" for under $1,500.00, SWEET!
Spark Plugs
Coils
IMT O rings
Cabin Filter
Fuel Filter
Air Filter
Clean MAF Sensor
thanks 4 all the replies, I bought the car!!!! now a couple of more questions. would you drive the car home about 35 miles with the issues that it has? can it cause more serious damage? (has a bad valve seal and is running on 5 cylinders) due to oil in one spark. i will fix everything before driving around but i want to have it at my house asap!
