Help! Please. No heat ever since they fized my power steering ac belt
So beginning of Nov I used mybheat all the time it would get so hot in a min I'd have to turn it off. Well the mechanic said j needed a new a c power steering belt mine was cracked well ever since I have no heat once in a blue moon if I freeze long enough the heat mayyyyy get warm Luke warm..... Wtf
joycesjag (01-07-2015)
Ok after rereading this several times.
-Did the mechanic put a new belt on or not?
--I cannot tell if he did or did not from the OP.
-Have you checked antifreeze level?
Reason why I ask, there have been several times over the years here, where inexperienced mechanics have bumped the brittle coolant overflow tube on the coolant reservoir and have cracked it to the point where coolant would drip out, eventually causing no heat. Again its very easy to put your hand on that nipple when looking at the front of the engine.
Just my thought.....
hilaryv215 (01-07-2015)
Alrighty then.
-Did he mention where its leaking?
-Did he mention that you need to get the leak repaired ASAP?
-Did he explain that when you run low on coolant that the heat will not function properly and also you will eventually seize the motor?
-Did he give you a quote on repairing said leak?
Jumpin' Jag Flash (01-08-2015)
Received 6,354 Likes
The way the conversation went? -
Mechanic: "I installed a new belt for you. There is a small coolant leak but, don't worry about it, it will be OK"
The way it should have gone?-
Mechanic: "I put a new belt on for you, but I accidentally broke a fitting on a hose in your cooling system and it is causing a small leak. The small leak could cause you to lose enough coolant over time to cause some problems and eventually could cause the car to overheat and damage your engine. If you will pay the small cost for the part, I'll fix the damage at no charge to you."
Or -
Mechanic: "I put the new belt on wrong and broke a small fitting.........I also damaged something in your hood latch mechanism........."
Check your coolant level before your cook your engine and find a new "mechanic."
Vector
Or -
Vector
The following 2 users liked this post by Vector:
Grant Francis (01-09-2015),
joycesjag (01-08-2015)
Dicque
09-19-2015 12:53 PM
1964Daimler
09-09-2015 11:28 AM
