Help please, s type grinding noise after tranny change
Hello all,I've just replaced the tranny on my 2000 S-Type 3.0 with a known good unit but I'm getting a grinding noise coming from the torque converter area,sometimes it goes but then comes back,any ideas please,could it just be low on fluid as I lost a little when replacing the oil cooler pipes? Or is it an installation error.
Thankyou
Thankyou
I would go with the trans fluid first and foremost.
You have mentioned you did loose some, so the trans will be lower than spec.
I would check it as per the book if possible.
If that is not feasable, remove the fiull plug, rear RH side of the trans case (hex plug), and add 1 ltr of fluid.
My better suggestion is to drain it, via the drain plug, then refill with fresh fluid.
I did a write up on this, and it is in the "stickies" at the top of this section.
neilandt (04-14-2015)
Well that's the oil topped up but still it's making the noise,it seems to come and go which I find strange.One more point is the selector is not just lined up right as it doesn't want to go to drive from neutral,if you go from 4th to d then it's fine,I don't supppose adjustment of the cable would make any difference to the noise.
BrentGardner
28
04-26-2024 03:08 AM
stanjag
08-30-2015 10:35 AM
Sshenton1975
08-30-2015 09:29 AM
