Hesitant anf restricted performance sometimes
I recently bought a 2003 jaguar s type r and its pretty hessitant when i hit the gas at first i thought it was cause it had been sitting for awhile so i ran a few tanks through it and its still there i ran codes and when it does the restrictive performance i get a cylinder 3 misfire but when im just regular driving cylinder 3 missfire nor the engine light comes on but all this happens when i get over 50mph please someone help thanks
<div style="text-align:left;">both p1316 and p0303 relate to your misfire . your misfire codes will most Likely be a bad spark plug or coil or plug well oil seal . causing a bad spark . This will be killing your cat converters so refrain from driving untill it is fixed. your Evap leak could be a bad fuel cap or a split Evap canister or vacume line . P1000 just means you have cleared the codes and the monitors have not reset . and they likely never will with an Evap leak .
Welcome to the forum.
From the unsolicited advice department:
It is okay to punctuate. I’m old and cranky. I’d like to help but it’s tough to decipher one very long sentence and/or paragraph. Slow down. Deep breath. Help us so we can help you.
Is your check engine light flashing? With code P1316, it typically does. The flashing light is a special warning to get your attention. It means the catalytic converter may be getting damaged by overheating, an expensive proposition. If the light is flashing, do NOT drive until you get that corrected.
I wouldnt worry about the P0456 right now. Concentrate on the P0303. That’s typically a bad coil or spark plug. As previously mentioned, if oil collects in the plug well, that can also cause that code.
Keep us posted.
Keep us posted.
SUPERBIG
07-08-2015 07:32 AM
asf1
02-02-2015 12:45 PM
