hesitation under throttle? ('03 STR)
A few days ago, I was awaiting the AAA tow guys while my car was stuck in what seemed like 341273489127 inches of slushy snow. While parked (with transmission in P), one of my friends asked me to stab the ish out of the gas pedal so he could hear the exhaust.
When I jabbed the pedal, I got instant response...until somewhere in the 3000rpm range, when the engine would do something I can only describe as hesitation...where the throttle cuts off. It felt identical to what happens at the track when I attempt to powerbrake, except the transmission was not engaged.
Is this normal? Running 93 octane fuel, and there are no codes that I am aware of (I assume there would be an indicator light). When the car is actually moving, acceleration throughout the RPM range is smooth and strong.
Man I actually realllyyyy hope it is a coil issue, because that would also explain the slow 1/4 mile times I complained about here when I bought the car (high 13s, with an occasional 14.1). However, wouldn't any coil issues (and fuel issues) also reveal themselves under full throttle?
You won't throw a check engine light if the fuel pumps are weak, BUT there is enough fuel trim in the software to not let it lean out.
Coil issues are more evident, as you'll get misfires. Coils don't really "sort of work"
What year STR and how many miles?
Take care,
George
Bring it up this weekend I'll scan it for you... Does it do it on the street or just that one time?
Take care,
George
Take care,
George
On the street the car is fine, no hesitation or other identifiable issues. Very strong acceleration all the way to redline. I've never had a car like this one, in terms of weird quirks (inability to powerbrake, inability to hit redline from 1 to 2, etc). This hesitation thing might be normal for this car; I just don't know enough about the STR to be sure.
Next time I am out of my neighborhood (too 'quiet' to rev the ish out of my car), I'm gonna try it in neutral and see what happens.
It's an '03 (noted in the subject line), mileage is just under 21,000. I wish I was free this weekend, but military training calls. Booooo National Guard...
Good Luck.
I dont think there is a problem. I think there's a rev limiter in park / neutral. Most cars have it.
Any problem would have manifested itself on the street too..
Take care,
George
Went to Autozone about an hour ago, scanner reveals P1000...so apparently I need to wait until the monitor cycle is complete? Scanner also showed 'pending', in a black box. I am unsure if this is referring to the monitor cycle being incomplete (after which, once complete and without any other codes, it will disappear), or if there is another code which will not show until the cycle is done. Anybody?
Jaguars always have a P1000 (for drive cycle incomplete) or P1100 for drive cycle completed.
You have a pending code. What that means is there's a fault that triggered a code, but either not enough time has passed (basically the car is waiting to see if the fault goes away), OR it was a momentary code (the car has to detect certain codes multiple times before it turns on the MIL). Did you read the pending code?
I can read it if it's still there.
Take care,
George
