Hey guys need some advice on another code!(P0442) Resolved
P0442: evaporative emission system leak (small leak)
This is what came up with the same code pending.
I am not sure what to look for, gascap maybe?
Can anyone shed some light on this?
This getting a little frustrating this is my second code in a month!
Dean
Dean
Received 2,263 Likes
devo357 (02-08-2013)
Is it possible that the code is actually p0442?
Jaguar Forums - Jaguar Enthusiasts Forum - Search Results
Hey Rick happy new year!
Ok I hope its that simple I'm gonna call the dealer and try and get one I cleared the code twice and it came back within a day.
My wifes Eclipse did this once and it was the gas cap but I do not remember if it was the same code.
The search will not come up with anything if I just pop in P0422 and I have tried different combos with words and just "codes/codes"
Dean
Dean
devo357 (02-11-2013)
The reason I asked is because S Type had some changes with gas tanks and canister clove valves and things. 07 S Type has whats called a DTML pump (diagnostic monitoring of tank leakage) pump and a COV (change-over valve) into one module).
P0442Leak detected. 40 thou.
- Hoses and connections.
- Fuel tank filler cap.
- Carbon canister.
- Canister close valve.
A fuel filler cap can cause a p0442 but it would most likely cause a p0455 gross leak (large leak). The dealership would perform a DTML test with SDD but I would first check gas cap and if tight then check both left and right fuel tank ports. To do this, removed back seat by sliding little black tabs to the drivers side of the car. 2 black tabs located front of the back seat under leather. slide tabs and lift up. Then lift up insulation with seat removed and you will see 2 black round covers, removed covers. Then you will see fuel tank ports. Look for signs of fuel leakage. Or you can erase codes and see if they come back. If you have anymore questions then post reply. Have a good day and God bless.
