Hey guys need some advice on another code!(P0442) Resolved
Received 2,263 Likes
devo357 (02-12-2013)
Be aware that the self test for the evap system only occurs when the tank is more that 1/4 but less than 3/4 full . When I was chasing the same code, I could fill the tank, reset the codes and drive about 150kms (numbers of days is irrelevant) before the CEL came on again.
OK I spoke too soon.
The code came on this morning and now its P0456 (very small leak)
So I guess I am back to square one going to check the canister in the engine compartment any other suggestions? I have been through a lot of threads and there doesnt seem to be a common denominator as far as this code goes.
Smoke test yes/no?
Dean
Smoke test yes/no?
Dean
Smoke test yes/no?
Dean
Smoke test yes/no?
Dean
Brutal suggested that with his experience the problem was probably the gas tank O ring seals on the top of the tank sender, I could smell fuel at times from the rear of the car.
They did a smoke test and said it was inconclusive, I showed them the message from Brutal, reluctantly they agreed to change the O rings (not really a big job) I don't know why they didn't just do it in the first place.
Anyway, this cured the problem and no more codes. It has been three months and it has not returned. The smell of fuel also has gone away.
I think the fuel smell was around for quite some time before the code was thrown only not very strong, I guess when the O rings worsened the smell got stronger and the code appeared.
Thanks again to Brutal,
#28
I know this is a year too late, but if you see this, let us know it went and what eventually fixed it.
I've got the same issue and have had it for 3 years. We don't have inspections in Florida so I only start working on when the light bugs me, and I don't don't drive it as much anymore either.
#30
#31
#32
Ha ha, that's funny, cause that's actually my next step on the list. Looks fairly straight forward. I'm going to pull the seat and take a couple pictures of the rings and see if the tool room has something I can check out for the weekend.
Did you replace both of them? Have you ever bought from a company called jagbits?
#33
#34
#35
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
They have been recommended by other members of this Forum as a reputable parts supplier, although I have not bought anything from them. But don't take my word for it. Do a search on the Forum and see what others have to say about them.
rachelstr
09-03-2015 12:59 PM
