HI! Please help with s-type r Transmission replace!
Couple updates, I changed transmission fluid with Castrol, but same story if I push gas slowly shifts from 1st to second almost normal, if hard 2nd gear is slipping and transmission fault message appears, in sport mode shifts are better but again if I floor the pedal it cannot complete the shift until I release gas pedal. OBD same code P0871. I guess only chance is to replace transmission.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I know you'll be losing money on this option but worst case scenario take it to another Jag dealer.
![Icon Fryingpan](https://www.jaguarforums.com/forum/images/smilies/icon_fryingpan.gif)
![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
Cheaper to buy your own elm327 but if not just write down all the TCM calibration data. PCM as well. I can't post the whole spreadsheet.
P0781 is passed from the TCM to the PCM i.e. it is really a code from the TCM, so Klaus will likely have met it (even if with BMW ZFs). A trans replace sounds crazy but that idea is coming from a place that knows next to NOTHING about the ZF. Ignore the jag place on that. To them it's like what you do with a broken lamp.
#31
I talked to Klaus ZF specialist he said I should do the Stall test and see if it slips or not, if slips then it very cheap 12$ part if not I need transmission. My does not go more than 1500rpms this means clutch D is bad and couple more thing. I will try to look for cheap used transmission, it’s very sad that I cannot use one I found from 2004 or 2005 model year.
Thanks and best regards to everyone who helped me on this forum!
#32
#33
#34
#35
... I'm in florida also, which dealerships did you try if I may ask? Jaguar near the millennia mall is really good if your in Orlando talk with John, he's the short British guy whose the tech for jag. He knows his **** inside and out, let me know.
#37
![Arrow](https://www.jaguarforums.com/forum/images/icons/icon2.gif)
Hey Relaxed Im sorry to hear your car is doing this. I live near Fort Pierce. I Know their mechanics in person. Unfortunatelly the only one there who really knows about Jags was Lenny and he is gone. He does own a Jag repair shop up in Melbourne. He is the only one I will trust. He was the Cheif mechanic down in Jaguar of Lauderdale for over 15years and he has been working with Jags for over 25 years. Anyways Melbourne is rather closer to you. Good luck!
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
