HID HOW TO and EUREKA!
1. Take the fircken bumper off- I tried for 3 hours yesterday to swap out the HID bulbs in situ and couldn't get the igniter to click into place. 30 minutes to remove bumper and headlights.
2. Remove the headlights to replace the HID low beams. Just do it. So much easier.
3. The REASON you can't "click" the igniter back into place is that when you remove it, it has a tiny "tab" that kicks the tiny plug out. (WHY???? I have NO idea) What happens then is the ring inside the igniter that slides over the pins on the bulb moves out of place and the igniter can't seat properly.
4. This took me two hours to figure out.
5. I unplugged the igniter from it little plug, put an old bulb into it, then removed- this set the ring in position. I then put the igniter back in place and BAM click right in. 2 seconds. I then finagled the igniter plug back into its socket and alls well.
Follow these directions and you will be done, with zero cussing, in about two hours MAX
hi
It only takes just over 10 minutes to take the bumper off
I took the bumper off and removed both headlights, split the lights, replaced all the adjusters, put new bulbs in, replaced the bumper and polished the headlight lenses, in just under 3 hours
its so simple to remove the bumper, especially if you look in the stickes which shows you where all the pins are
cheers
Joe
cheers
Joe
hi
cheers
Joe
cheers
Joe
Lt0302
28
01-14-2022 09:27 AM
RDMinor
12-12-2015 10:27 PM
Bacardi 151
29
05-01-2009 09:21 AM
bobby181
06-28-2008 11:37 PM
