high flow i/c pump upgrade
I think someone said this might move a bit more volume over stock
Bosch 0392022002 - Bosch Intercooler Water Pumps - Overview - SummitRacing.com
Bacardi 151 (01-03-2012)
i've seen the i/c pump on eurotoys but i find it under the xkr but in the description it said that it's also can b use on the str but the i/c itself it was only for the xkr. just wondering if upgrading the pump alone is good... up here in jersey i cold now but for the summer time i know heat soak can b a B#t$h... lol btw this is my 1st F/I car..
I don't think anyone has ever presented any credible evidence that a pump with more flow improves things?
So log the temperature drops starting this spring and through next fall to see how the system performs during the various weather conditions. Then pull the current pump out and measure the flow. Find one with higher flow to install and then log the effects the following year.
Of course the factory might have already done this for the stock 400HP and picked a suitable pump. I sure hope so.
The Bosch pump mentioned is the best alternative (and 200$ cheaper than eurotoys one which is probably the same unit…), and should provide about 14% more flow. Too fast or to slow of a flow isn't good, it should be designed right for the purpose/system. The coolant needs to be cooled by airflow, so best focus is on more airflow thru the radiators, or a larger surface radiator, but I am not sure what fits the Stype.
Get to know the car for a while.
Then re-read the postings in this thread.
One thing to keep in mind is that plumbing for the cooling system and intercooling system on this car is both torturous and very crowded.
What does that mean?
Well, getting to stuff isn't all that simple and there's a lot of plastic involved.
Why do I mention that?
1. The intercooling system and engine cooling system are interconnected. Now before you go and get your panties all in a bunch over this the connection is only at the highest points in the reservoirs for the two systems so that there's only one fluid system and pressure expansion tank to deal with. Typically the fluids don't exchange on a thermal loading basis so your engine's coolant isn't going to be pre-heating the intercoolers.
2. It's easy to break one of the plastic components in the cooling system because IMHO Jag used crap plastic there. Go search on coolant/overflow tank failures. The nipples on these are easily cracked whenever any work is done in the engine compartment.
So if you start screwing around and removing hose clamps without the special tool (which means you're a masochist) and man handling the complex routing of the hoses then you're very likely to crack one of the custom POS plastic pieces.
Then to make yourself feel even better search on the under the supercharger coolant hose leak. Have a couple of scotches first.
SO PROCEED WITH CAUTION.
Just enjoy the car for a while. Then if you feel compelled to "tune"/ futz go read some of the threads about some of what people have had to do. I've only had mine 1.5 years and there's been a ton of activity on all of these subjects in that time.
best of luck.
Bacardi 151 (01-07-2012)
You're gettin' in the weeds kinda early here.
best of luck.
best of luck.
thats what im goin to do ?'s is ?'s this is my 1st f/i powered car and ?'s that i never asked. had my last car for 5 year only mods i done was only a tune and intake thats its. this cars is way faster the my last on and much more comfortable..
