high milage oils & drain plug gasket
Not trying to start the "dreaded oil thread" but I need to change my oil - doing it myself this time. 05 S Type 115,000 miles 4.2L V8 NA - No leaks, weeps, burning etc., always run on 5w30 semi synthetic.
Is it time to switch to a "high mileage" oil?
How long can one continue to reuse the oil drain plug gasket? I understand it is a "rubber" gasket and I do not recall ever being charged for a new gasket. Who knows - it might have been replaced with a typical crush washer at some time but the PO and my records indicate it has always been serviced at a reputable establishment.
Anyone know the torque specs on the drain plug and oil filter?
An old American? saying comes to mind.
If it ain't broken, don't fix it!
I would continue on the oil you use. As a matter of fact, some years ago, FORD changed oil (pun intended) their recommendations from a higher viscosity to a 0. They are most likely doing that to make sure the furthest parts of the engine gets oil as fast as possible, so a thin oil,
And I agree, 100000 miles on an engine well looked after is not what it used to be.
As a complete aside, I am always very surprised when I look at my Jaguar engines, and see how clean and fresh they look inside. Other engines in my cars are often dirty and crusted and black inside when filling oil. The Jaguar engines have a lot of my respect, compared to anything I have seen!
S-Type Owner (06-30-2020)
The recommendation is to replace the oil seal every time. A rubber seal is not considered re-useable.
From internet search................
High-mileage oils have ingredients to take care of older engines, like conditioners, seal swells, antioxidants, detergents and wear or friction additives. ... The higher-mileage oils are formulated with seal conditioners that increase flexibility and restore shape, which can help prevent leaks in the long run
My XKR has 74,500 miles, it burns no oil, however, it has sprung a small oil leak at the front, I assume front left side timing cover gasket. The leak seems to be coming from nearby the power steering pump (I don't have a power steering fluid leak, I checked and the level has not changed). When I changed the valve cover gaskets, the engine looked remarkably clean. I am not looking forward to changing the timing cover gaskets and crankshaft seal because all the accessories and radiator have to come out for this job. I was thinking that perhaps high mileage oil could reduce my leak. They claim to condition and renew seals and owners anecdotes seem to back this claim for other brands.
I am on the fence of making this switch, or if it would be a bad idea and I am better off biting the bullet and replacing all the gaskets. The leak is not too bad, but I do have to top it off every 6 months or 2500 miles or so because by then it has lost about half a quart.
giandanielxk8 (07-01-2020)
Gerard Radimaker
02-03-2016 01:24 PM
plums
06-27-2015 11:02 PM
BKSinAZ
03-09-2015 04:09 PM
