Hints, tips, and tricks...
#101
Foldin Mirrors
More things in the handbook that people tend to overlook:
1. to latch Recirc, press and hold Recirc until you get a double beep
2. to use the powerfold door mirror feature (if you have it), on the driver door switch pack make sure the foremost rocker switch is centred then briefly press the rear part of he foremost (circular) switch (hope I made this clear!)
3. to stop the EPB applying, hold its paddle down as you switch off engine and remove ignition key (preferably with foot on the brake!)
4. check whether your car has a keyhole in the trunk (boot) lid (hint: it usually/always? does) and make sure it works - ready for the time you have a flat battery or similar
5. learn where the inertia switch (engine cut-out) is - that way youll never need it
6. try the factory-supplied jack and tire iron (correct name?) as if changing a wheel and think what you'll do if you get a flat tire
(6b. change the lug nuts)
#102
Red Fox (03-21-2016)
#106
Does anybody know if you can retro fit power folding mirrors to a 2006 S Type 2.7 Sport?
#107
Just re-read this sticky, cool.
Printed out some of the stuff and went out to the workshop to try them. At this time of night! Had to.
This is on a 2002 registered S Type 4.0L.
I don't have powered mirrors, bummer.
All doors unlock on one press of the button
Global opening works off the fob, but not global closing.
However it will global close if I use the key in the door and hold it in the lock position.
Can't get the cup holder to pop out, but I'm not so fussed about that, plenty of storage in this car.
Now then, how to program the fob for global closing.................
I'm sure someone has cracked it somewhere without going to the *******s by now?????
#108
Received 6,361 Likes
#109
#110
#111
#112
This thread is great. I recently picked up a 2002 S Type for a cheap deal from a guy my husband works with. There is a terrible grinding sound from the rear end (why he parked it and sold it cheap). I am betting that we can change out the bearing and probably knuckles on the rear end and have a great car. It doesnt have a key fob, but appears it was probably keyless entry to start. I may just have to travel 2 hours to the nearest dealer and have one programmed if it all works out. Thanks for all the great information on this forum!
#113
#114
Rogozskat (05-29-2018)
#115
HI All, Lots of cool tips here. I was reading on another post about closing all windows and sunroof with the door key. Someone mentioned that they will unlock also. I tried it on my 2007 S-type and Voila it works. Both directions for mine. To lock doors and close all windows and sunroof turn the key to lock and hold it. The doors lock while the windows and sunroof close. You have to hold the key in the lock position until everything is where you want it. If you release the key, everything stops where it is, but doors are locked. Unlock is the same thing, turn key to unlock and hold until windows and sunroof are open to the point you want. Doors are unlocked. Hope this is new info in this thread.
#116
Another for hints and tips.....
My 2006 S type has 2 memory settings. I use setting 2 to have my side mirrors point down to the kerb. Adjust mirrors to avoid kerbing and save in memory 2 so when parking up or maneuvering just slip shifter into park
and select memory 2 and the mirrors will point down. ............................................IP
Silver Flyer (01-28-2021)
#117
M/Y 2000 and my car has both global open and close. Not sure what you're talking about when you say 2002.5 onward when my 2000 has it.
#118
#119
#120
You'll get a better response if you post your problem in the S Type tech section.
