Hmmm that's weird...
Hi guys
Lately it's gotten warmer down here in Zurich, and my S-type's steering wherl makes these weird squeaks, I mean it sounds like an old door that hasn't been greased. It used to do this before too but now as it gets warmer outside the squeaking gets more intense. What should I do about it? Should I worry? :/ I love this baby, even though it's old and it's got quite a few miles on board, so I don't want anything bad to happen.
I just got a 2005 S-type and am experiencing the same steering wheel squeaking noise, especially when the car is warmer. I noticed another member mentioned about a TSB for this. I was thinking I would take the plastic steering column cover off and oil the plate where the electrical contacts for the steering wheel-mounted controls touch. But this might mess things up. So, like Ioan-Stefan, I wonder what the fix is for this?
Received 6,307 Likes
OK, to be clear on what I am experiencing, it is *not* a noise coming from the power steering system. It is a squeaking or zipping noise coming from the steering wheel inside the cabin when the wheel is turned. I have heard this kind of noise on other cars, but in my S-type, it is louder and more out of character with the quiet and smooth nature of the car and so is something to remedy. It is getting louder as the temperatures warm.
I located this TSB on JimC64's stickied thread: JTB00034, with PDF file name "Steering Wheel Noise TSB". This appears to be addressing a bearing or bushing problem. Quote from the TSB:
CONDITION SUMMARY:
STEERING COLUMN ADJUSTMENT TO RESOLVE NOISE
Situation: Increased loading on the bulkhead bushing can result in noise coming from the steering column when the steering wheel is turned.
Action: If a customer expresses concern about the steering noise symptoms and they are verified, reposition the lower steering column to release pressure on the bulkhead bushing as outlined below in the Repair Procedure of this bulletin.
My guess was the electrical contacts for the steering wheel-mounted controls. Is the sound really more likely caused by "loading on the bulkhead bushing"?
CONDITION SUMMARY:
Received 2,263 Likes
+1 on Norri's comments. The squeak is NOT in the steering wheel or column, despite what owners might think. I'm surprised that there's still cars around that have not had the TSB done. It's JTB00055 found in the TSB sticky at the top.
Then why is there a separate TSB on *steering column noise* with a fix to adjust the steering column inside the cabin that is unrelated to the power steering fluid, etc.? I know when noise is coming from a location inside the cabin 2 feet from my ear as I carefully listen, and noise coming from outside the cabin in the power steering system (pump, rack/gear, other mechanicals located approximately between the front wheels under the hood and not inside the cabin).
GT42R (03-05-2013)
I don't want to hijack the Zuricher OP's thread and conflate his issue with mine. I am new to Jaguar S-type ownership and I saw his post and thought, "me, too!" Our issues may be entirely different, though.
MY steering noise is not a squeak. It sounds something like the sound of a clothes zipper, AND it transmits a haptic vibration to the steering wheel and my hands, and its frequency is directly proportional to the speed at which the steering wheel is turned, and varies in intensity from time to time, but I don't actually know if it varies with temperature. Because of the nature of the sound, and the kind of low-intensity but direct and non-filtered feeling vibrations that are transmitted to the steering wheel and my hands that are different than vibrations I've felt before transmitted to the steering wheel from the steering gear/system in other cars, I am about 95% sure the sound and vibrations originate inside the cabin. I still think it is just a sound from the electrical contacts for the steering-wheel-mounted controls/buttons.
![Icon Neutral](https://www.jaguarforums.com/forum/images/smilies/icon_neutral.gif)
Why are you fighting the solution??
The magic juice is only about $12 and it won't hurt anything if that's not the problem. Try it first and then get complicated.
If it was done properly you should have a sticker on top of the P/S pump with the part number of the additive.
You can get the additive from Jaguar or Ford but they do have different part numbers.
Tee-eye no worries, we actually have the same issue apart for the fact that mine squeaks and doesn't have the zipper sound
well I guess I'll try the additive and we'll see if it gets better. So thanks a lot for the answers
real professionals out here
not like at the dealer where I called and they told me that it is most certainly the power steering pump that needs replacing... This guys here would do anything to charge you as much as possible. Btw, do you guys know where I could order the additive in europe? From the UK or something? Cause I'm pretty sure here they'd try to overcharge me as much as possible, they tried to charge me about 2000 dollars last month only to change the spark plugs
![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
![Embarrassment](https://www.jaguarforums.com/forum/images/smilies/redface.gif)
I read the TSB: JTB00055 -- Power Steering System Squeaking Noise Repair Procedure, which I found on Jim64's stickied thread with a ZIP file name of 'Power Steering Squeaking Repair Procedure.zip' containing a PDF with file name of '67 Power Steering Squeaking Repair Procedure.pdf'. Ioan-Stefan (John-Stephen?) -- you need to look at this Jaguar technical bulletin. The procedure to follow when adding the additive is unbelievably specific -- turns of the wheel this way and that for various amounts, holding for so much time, maintaining certain engine RPM at certain points, and using a thermometer to monitor fluid temperature to keep it at 100C +/- 5C. Wow. I'll let you guys know after I've added the magic juice with the prescribe procedure with a few incantations for good measure.
By the way, Ioan, I'm curious to know if Ford dealers in Switzerland carry the additive. The Lincoln LS on the DEW98 (?) platform was not sold in Europe, I don't think, though sometimes some European countries (often Switzerland and The Netherlands) get American cars not sold widely in Europe. Maybe other Ford models had the same problem. Anyone know? If Ford Europe doesn't carry the additive, maybe check around for a Jaguar dealer willing to send the additive to you for a reasonable price if your local Jaguar dealer is being unreasonable. (Or use the standard price for the additive elsewhere to beat the dealer down to a reasonable price.)
No offence but the two of you are making a mountain out of a molehill. All Jaguar dealerships carry the fluid in their parts departments. North American price over the counter is around $10-$12. UK price is around 8-10 pounds.
You'd spend more in gas running around to different dealers trying to get a compatible fluid at a 'bargain'.
Norri (03-06-2013)
Larry-Cleveland
09-25-2015 08:42 AM
Andrew Fanshawe
09-14-2015 07:40 PM
RaceDiagnostics
09-13-2015 02:22 AM
