How to bleed air from the cooling system
If you don't already have it, here is a link to the X200 Workshop Manual:
https://www.dropbox.com/s/jp6343385h...e_FSM.pdf?dl=0
The cooling system specifications and bleed procedures are outlined in the Manual.
neilr (12-06-2019)
The OP's car is a 3.0 V6 RHD.
Simon Pickering (12-10-2019)
Simon:
From your multiple posts over in the so called "British" Jaguar Forum, you have reported that your radiator has a small leak, you have also asked if it is difficult to replace replace the unit.
If your current radiator is leaking, it will likely suck air through the break as the engine cools and you will never properly bleed all the air out of the cooling system. Do the replacement.
I Sussed it , when there is only one bleed on a 1999 S Type 3.0L... either
Make a large funnel fit and seal into the bleed plug (after you lever it upwards,and a cable tie to keep it from popping out) ,it needs to be like in the pics or fit what's in the other pic ..
Hi, new rad, CVV and serpentine belt, all waiting for it to stop raining to refit .. i read one manual last night and it misses my 1999 out ,i have 5 ports on the CVV and no bleeder,i shall support a funnel from the bonnet and slowly fill from there, i think it will self bleed to some extent ..we will see i suppose ..thanks sir ....Si
NovatoRob
25
09-18-2014 09:32 AM
iretribution
12-28-2013 11:32 PM
