how can i check the tranny fluid on a 01' s-type?
I would add one word of caution and try to remove the small allen or torx plug in the drain/stand pipe before draining the fluid. If the small level plug is too tight and strips then you will have no way to correctly check the fluid level. I always keep a spare drain/stand pipe (XR852333) because some are overtight or the locking sealant sticks it tight. The later ones should be TORX and early ones were ALLEN.
The TEMP range for fluid level checking is stamped on the rear of the gearbox.
bob gauff
bob gauff
No, do not drive first. You know I thought something was missing from that procedure. The level should ideally be checked at 100 deg. F, but the allowable range is 80-20 deg. F.
Driving the car first will most assuredly take the temp too high. The intent is to use a scantool capable of monitoring the trans temp while doing the level check. Not everybody can do that.
Good luck!
Good luck!
aholbro1
08-05-2021 05:02 AM
neruda
10-18-2015 01:19 PM
Wes Steenrod
09-06-2015 06:52 PM
