How do I disconnect the wiring harnesses from the bottom rear of the stereo?
Can someone tell me how to disconnect the two small harnesses from the bottom rear of the stereo/climate controls?
I am about to install a double din aftermarket navigation system in my 2005 S-type. I'd like to pull out the entire stereo/climate control unit, but don't know how to remove the two small wiring harnesses that connect to the rear of the panel which contains the hazard lights, remote door locks, and seat heater controls. All of the other harnesses to the stereo and climate controls came off easily by simply pressing a tab on the connectors.
George
Thanks. No luck getting them out yet. I have another question. I have the Autoleads PC99-X47 on order. The adapter has and ISO connector on it that Autoleads says will fit the head unit. However, it doesn't appear that the head unit (Alpine INA-W900) will fit an ISO connector. Please advise...did you have to splice and reconnect wires using the PC99-X47?
Even if you got the regular harness it would come the same way.
Where did you order your Autoleads pc99-x47? Did you find a stateside supplier or did you order from the UK? Thanks in advance,
George
I ordered the PC99-X47 from Dynamic Sounds. See http://www.dynamicsounds.co.uk/autol...or-p-9075.html
Do you know how to route the navigation receiver cable, so that it sits on top of the dash with little or no cable showing?
Dicque
09-19-2015 12:53 PM
philwarner
09-05-2015 10:05 AM
