How do I edit VID Block with JLR SDD software please?
Can anyone please explain to me how I use JLR SDD software to switch off the 'Speed Limiter' fitted and on from the VID Block.
After a PCM change by my friend, which was almost 100% successful, it has left my car setup with the speed limiter on, but my car does not have a speed limiter or disable button. Only a cruise control. Which can't be used now while it is hard set to use Speed Limiter?
So as I have SDD software etc, my question is How do I edit the VID Block with JLR SDD software to switch Speed Limiter off please? What steps please?
I have read the VID Block pdf, but it talks about WDS software, which I do not have.
Please Help.
Thanks for your time and help in advance.
Kind regards
Mark
Please Help.
Kind regards
Mark
what speed is it limiting at ?
a speed limiter is normally determined when programming the country of origin .
if it's in the vid block id recommend talking to CAMBO to alter this .
my guess though is it will be within the country of origin file .or a basic click the box configuration choice.
or MAYBE you have the valet key programmed and in use ?
knzwmn
35
03-07-2019 07:25 AM
