How the F*** do you remove the damn lights from our cars??
RE: How the F*** do you remove the damn lights from our cars??
Paul,
I PM'd and site emailed you to let you know that I have a pdf of instructions from JTIS for removing the front bumper if you want it.
I've done about this 4 times already and the first time is kind of tricky, after that it's not so bad. I'm in the process of doing a retrofit with OEM
STR assemblies on my 2000. It is a pain in the *** to say the least. God forbid a bulb change is needed. You wont be able to change the
bulb without having to drop the bumper again. The back of the headlight assembly just about kisses the radiaoter cross member support.
Mike
Mike
Need some more info to clarify your question? By retrofitting headlights do you mean a headlight assembly swap? I believe Jaguar made some small changes to the 2003 S-type, I’m not sure if 2003 headlights would bolt right up? Can anyone confirms this?
BrentGardner
28
04-26-2024 03:08 AM
xjrjag
10-27-2021 11:48 PM
SingBlueSilver
08-27-2015 02:20 PM
