How far on a single tank in STR? I now know!
In my experience you can get some debris that will settle and sit in the bottom, as sometimes the baffles in the fuel tank that keep the fuel from sloshing around will also keep all of it from completely draining out of the bottom as well. So even though the fuel out line is at the lowest point, there can be some instances where not all of the fuel makes it to the pickup - and some debris in that fuel will kind of impede it from running to the pickup as it normally would.
I agree far less of a problem than it used to be. However there can still be debris picked up from the fuel itself that is heavier than the fuel and will settle to the bottom, and the baffles will help in keeping it from completely mixing and moving to the filter.
With ethanol cut fuels these days, I'm not sure if phase separation could also play a role in debris suspension or not.
Received 2,263 Likes
Neither is likely to occur on a car.
Tell me more about the Mafioso intake. I just purchased 2003 S-type R. It is all black and I did just get tint done which will likely be only cosmetic upgrade, but I am interested to see what would be some first steps performance wise. Thanks for your input!
2) Possible IMHO - vehicle with perhaps 1/4 tank of fuel stored over the winter months 60-120 days or more. Careless storage method of course so let's hope it shouldn't happen in a car, but possible. But I agree not likely.
But we are straying a bit from the topic (and about at the limits of my knowledge of the matter ) so that's all I got.
SoCalJagS
09-27-2015 09:20 AM
