How hard is it to add an Ipod connection?
I've installed two ACM's. The second time was easier than the first!
The kit comes with all the parts you need and a comic book of pictures for instructions. Other than ripping your dash apart, (which is really easier than you might think) the hardest part is installing the module in the center console. The kit is about $300 from the dealer. I bought one from a member on the forum and the other from Nagey Jaguar, they both work perfectly. You will be glad you made the investment
Blue Lion (04-13-2011)
Just be aware that when you use the Jaguar supplied ACM you lose control of the the Ipod from the Ipod side. It's treated/emulated as a gigantic CD player. Everything is controlled from the Jag's system and that is limited to next track/prev track with no album or artist or song display. It pretty much sucks. If you can get a line-out interface for the Ipod then you can use the aux input that the ACM offers and utilize the Ipod's own interface as god and Steve Jobs intended. ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Just FYI, the latest firmware update from Dennison overcomes that problem. (Locking out the ipod click wheel controls).
Edit: Info here:
http://www.jimrothe.com/jaguar/acm-b...are_for_iphone
Personally I'd google or check ebay for the Harman / Kardon Drive + Play kit. Intuitive controls and real display with a line output without having to fumble with a handheld device in motion.
Take care,
George
Hey,
The ACM would still be needed, sort of.
What the drive + Play kit is is an alternative method of controlling the ipod. It gives you an ipod like click wheel, and a screen showing you what the ipod is doing.
You can either get the audio signal into the radio via the included FM transmitter setup (poorer quality, but no need for the ACM). Or via a direct line input to the ACM. I think it also adds an aux input as well. Much better than trying to control the ipod via the 5 playlists the ACM gives you.
Take care,
George
Take care,
George
Playing with this stuff while driving is just plain nuts to me. I'm going to use playlists and random mix with my version 2 Sansa Fuze. I may add Rockbox to it as well. Just as soon as that's fixed for my version of player. These MP3 players are $50-60 bucks in 8GB form with up to a 32GB Micro SDHC reader and they sound great playing the Flac or Wave format. The base charger with line-out was under $20 so if I want I can play it through my receiver. But that's not my intention.
Hey, I'm not driving a brand new top of the line car with all the latest electronics on it. I wish Denison provided more capabilities for the Jag like they do for Audi but this won't be so bad.
If the new firmware for the ACM really does allow the Ipod to fully function then that's a great choice too. More expensive though.
I wonder how the Jags steering wheel controls will interact with the manner in which you're operating the Ipod from the Ipod's side?
You get 5 playlists in the the ipod, which are specifically named.
The Radio reads these as Discs 1-5 (as if the CD changer is present)
All the radio displays is Disc X - TR X so the first playlist is Disc 1 track 1, after 99 tracks, it restarts to 1.
You can control the ipod with the new ACM firmware, now as far as the steering wheel controls, If you are in one of the predefined play lists, track up and down do just that and scroll through the playlists. (I think this works regardless of what playlist you have set the ipod to play). Volume works fine regardless (it just controls the radio's volume).
There is no way to get a line-in input into the regular, or navigation radio, without the ACM.
ACM gives you 3 options - The somewhat limited ipod control we described before.
RCA Jack line level inputs - you can connect anything you want to.
USB direct mp3 file playing either from a portable flash and or hard drive.
If you want another audio source into the stock Jag audio system, you need the ACM, bottom line.
Take care,
George
Take care,
George
I know how the ACM works. I think there are other alternatives for the non-nav oriented radio though? It wasn't an issue for me so I didn't spend much time looking. So what I'm wondering is if the the Ipod will now display artist/album/track info while it's playing? It was just a blank screen before. I know nothing is going to show up on the Jag's touch screen. Too bad about that though ...
I have as yet to find any USB connector or even the main ACM box in my car. I just have the AUX-IN, Ipod connector and switch in my center bin. It was located where the install directions suggest to mount it. Until I find that USB connector any firmware updates are kinda tough ...
couldnt he swap the headunit for less than 300 now?? i mean the kit and wiring is what 120 at the MOST? and you talking about 250 for a decent single din with BT and full ipod access..............then with the instructions found here and online, a few hours of time, and walla --------------------------- new radio
Not in an Alpine or nav car. Alpine car needs at least a 4ch amp and some passive crossovers (to reuse the stock speakers), in addition to the head unit.
Plus single din is gonna look like absolute crap in that dash, it NEEDS a double din, even if it doesn't have a screen.
Take care,
George
Yes with the ACM update, the ipod / iphone shows everything, and you can control it using the ipod's click wheel as well.
Take care,
George
I think there are only 2 torx screws holding the center console storage compartment bin insert into the console itself. Should be able to pop that out in a few seconds.
I've had the whole works apart, the only thing that confounded me was getting the ashtray mount out. Everything else is pretty straightforward.
I need to find a local copy of the ACM install instructions. I'm wondering if someone decided they didnt "want" the USB, and possibly left a cable out, or if it is molded into the box.
Take care,
George
I had all of that out too. Removed the touch screen as well.
No box anywhere. The wires just disappear under the carpet in the front and not into the dash either. But it does actually work as advertised! So I'm speculating that the box is buried under the carpet on the left side of the passenger (LHD) foot well.
I hope it is just a case of not connecting up a USB cable on the main box.
But I won't be using the USB for music anyway. My ACM doesn't have the little light on it. I've read that there were at least 3 versions of this thing. Is it possible that one version had no USB? Seems doubtful to me because that's the onlypath for all firmware upgrades.
The ACM instructions like all of their kits is almost useless. I think I've seen 2 or 3 versions. But they suggest exactly where to mount it. Whomever did mine ignored all that.
