How to headlight repair stype FAQ
Unfortunately, in MD, all inspection stations have the fancy leveling testor. It sucks because if it wasn't for the inspection, your fix would have worked perfectly. Thanks for your help.
Edit: Pics have been added. Taken with my cell phone. I might take some with my canon digital this weekend, these didnt come out as well as I had hoped.
Received 2,191 Likes
also I tought I had mentioned the screws become your height ajustment now. screw them in to raise, out to lower. You really should have been able to get them at the right height to pass
Before Brutal proposed his much simpler solution, I repaired mine by cutting out the adjustment mechanism at the back of the assembly and replacing it by a threaded rod with a ball bearing ball at the end.
It works perfect and provides full adjustment possibility. It is much stronger than the original device but requires some tools to fabricate and also requires removal of the light assembly (that means dropping the front bumper).
You can repair the ones you changed and sell them...
Herve
Herve
tmurray (06-27-2012)
Hey Brutal:
I've seen conditions such as this in my travels especially with the SAAB 95'! Usually it's just 1 side that will go ****-eyed. What's going on when all of a sudden the Right drops down & the Left points left?
Do you advise this fix for this condition as well??
RSVP,
tbjcc001
RSVP,
tbjcc001
#32
This is a great thread. Why do the lights have the self leveling feature in the first place? I see no value in it.
Mine broke (headlights did not lift at all) and thankfully the extended warranty covered it. The cost was around $900 per headlight! Outrageous! Lately it seems my headlights are pointing a bit low. They lift and settle when I start the car but don't seem to point high enough.
Does this mean I need to do the procedure described here?
#33
The self leveling feature is only on the HID lights. It is required in Europe to try and stop people from blinding on coming traffic. Jaguar had to install them, they had no choice it is the law. They are a small manufacturer so even though we don't have a law for this in the US. It was too expensive to have two different versions for such a low production car.
#34
DSt1 (07-21-2013)
#35
you need to manually adjust them on top off the housing. The electronic leveling IS required also in the US. This is so if you put 3 of you fat freinds in the nback seat and their luggage in the trunk. youre not going down the road with your light s pointing up into everyones eyes cause HIDs are WAY brighter and further reaching than halogens. The auto level still is usually operable even when broken, but its the upper pivot/adjuster that breaks so the motor to level has nothing to pivot the inner housing on. And Valeo makes the headlights for Jaguar which is a large supplier to alot of auto manufactures for lighting, CD's. nav etc....By putting a screw throught the front of the housing you give the housing something to pivot and adjust against again. And you now use that screw to level up/down by screwing in/out as required. The leveling should still operate unless 1), headlight leveling module needs to be recaled/programmed(dealer, and even sometimes you have to do after headlight replacement) or 2) your housing is totally broken inside. in which case the screw will fix your lights so they can be manually adjusted, but if an inspector for safty sticker checks the auto level cause your state is ****(Texas is not) then you may fail, or maybe you need to find a different inspection place!
#36
#38
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
But seriously, thanks for the explanation. Makes sense to me now.
#39
Guest
Posts: n/a
A big thank you for this arcticle. I've had exactly this failure on my S-Type R. As a result it failed it's MOT, the repair cost from Jag (need to replace the whole light unit) would have been £800 !!! However, 20 mins of deciphering pictures and 2 mins of making the repair fixed the problem.
So again thanks for the advice.
