How insert Drive shaft inner
Hi Guys
I have searched for a day but I cannot find the answer to "How do I insert the inner drive shaft into the Diff".
The car is an S-type 2004 and needed the reluctor ring replaced. The drive shaft just slid out from the diff with a little knock with a hammer,
It does NOT just slide back in. Keeping the shaft straight and level it enters about an inch. Turning the shaft it does not turn and therefore I believe the spines are aligned but it will move no further - even with a few knocks on the outer spline (nut half replaced) with a club hammer.
What am I doing wrong?
Thanks for your help,
Brian
Brian
Elskan (03-30-2021)
Thanks, Andy
It does seem that it goes in as far as the ring but is blocked. Is there any position on the splines that the ring should be when inserting?
I cannot find an image of the ring - I take it that it should be partly open?
This all started as a very simple job. I bought the car knowing there was a fault with the ABS. I thought - just charge the battery - Nope. Just replace the sensor - Nope. Just hammer on a new reluctor ring - Nope. Had to take out the axle. Amazing how a planned 10-minute repair can take days!
Regards
Brian
Regards
Brian
The following 2 users liked this post by Elskan:
Datsports (04-02-2021),
S-Type Owner (03-30-2021)
penguin
03-18-2013 12:10 PM
