How many miles are on your S?
#42
#43
#45
http://www.amazon.com/Motorcraft-YG355-Heater-Valve/dp/B000C5HZEM/ref=sr_1_2?ie=UTF8&qid=1353781497&sr=8-2&keywords=Motorcraft+Jaguar+S-type+valve
The part number you want is YG355.
#46
2005 STR w/ 74K miles
I have had my STR since 7K miles and now have 74K miles. I've replaced the following items:
- Tires - Continental SportContact 2, Toyo Proxes T1-R and two sets of Continental DWS
- Brake Pads - Akebono front/rear brake pads and still using original rotors (anybody else use their OEM rotors for this long?)
- Battery - AutoZone
- Water Pump - Failed and replaced the following at the same time for preventive maintenance...DCCV, Serpentine Belt and Idler Pulley
- Plugs and Coils - Replaced all but did not need to. Misfires and performance issues were caused by bad catalytic converter
- Catalytic Converters - One failed and replaced both with aftermarket, now running both OEM again. Aftermarket Magnaflow cats failed and they were too loud anyway
- Radiator Fan - Replaced due to failure
- Gas Tank Plastic Seal Cap - Failed under rear passenger seat
- Heater Hose under SC - Replaced but appeared to be in very good condition. Since I had it apart I replaced the following items too...SC Pulley (Replaced with 2.6 inch/3.0 lb.), SC gear oil, many Gaskets and Hoses
- Inner Tie Rods - Replaced both sides, one side was bent
- Motor Mount - Diver's side failed
Staatsof (11-25-2012)
#47
You think you could put some mileage markers next to those repairs? Mine has a lot less miles but I'd like to know when to be "out of town" when those things hit ... LOL
#48
#55
Late... mileage info and updates
Mileage info and updates…
- Tires - Continental SportContact 2, Toyo Proxes T1-R and two sets of Continental DWS, edit/add: ~92k miles on third set of Continental DWS and need to change again
- Brake Pads - Akebono front/rear brake pads and using original rotors (anybody else use their OEM rotors for this long?) edit/add: changed at ~22k miles,
edit/add: now at ~92k miles, still with the Akebono front/rear brake pads and still using original rotors, everything may need changed this Spring, 2015. - Battery - AutoZone, edit/add: ~40k miles
- Water Pump - Failed and replaced the following at the same time for preventive maintenance...DCCV, Serpentine Belt and Idler Pulley, edit/add: ~30k miles
- Plugs and Coils - Replaced all but did not need to. Misfires and performance issues were caused by bad catalytic converter, edit/add: ~45k miles
- Catalytic Converters - One failed and replaced both with aftermarket, now running both OEM again. Aftermarket Magnaflow cats failed and they were too loud anyway, edit/add: ~50k miles
- Radiator Fan - Replaced due to failure, edit/add: ~55k miles
- Gas Tank Plastic Seal Cap - Failed under rear passenger seat, edit/add: ~50k miles
- Heater Hose under SC - Replaced but appeared to be in very good condition. Since I had it apart I replaced the following items too...SC Pulley (Replaced with 2.6 inch/3.0 lb.), SC gear oil, many Gaskets and Hoses, edit/add: ~60k miles
- Inner Tie Rods - Replaced both sides, one side was bent, edit/add: ~30k miles
- Motor Mount - Diver's side failed, edit/add: ~60k miles
- Coolant Tank - edit/add: ~85k miles
Last edited by 1320racer; 03-17-2015 at 09:47 AM. Reason: correct and update mileage
#56
#58
2005 S-Type 3.0 now pushing 88,000 miles....
It's been relatively trouble-free the past year or so. We did its first ATF drain-and-fill last November at just over 85,000 miles. I felt it was time and I went with Mercon SP (which has done quite well). Just put the car in the shop this morning to have the A/C system checked out. It has been blowing ambient air for the past few weeks and with afternoon temps now reaching into the 80s on some days, I'm sweating like a pig even with the windows down. This polar bear can easily live without heat but I cannot survive without A/C....
#59
'08 4.2 58K miles (got it 05/13 with ~48K miles)
Had to replace both HID headlamps, one under warranty one not... =:-0
Also replace the front fender liners because the were both badly cracked.
Did pads and rotors
Just now the radio speakers have stopped working
Jaguar - it's not an automobile, it's a Motorcar
Did pads and rotors
