how to Programming keys procedure ENJOY
Guest
Posts: n/a
Key Programming Using Two Programmed Keys
1. To program additional PATS keys, a minimum of two valid keys must be available(if only one key is available, it will be erased and reprogrammed with the new key).
2. Key programming using two programmed keys.
Insert the first valid key and turn to the run position for a maximum of five seconds, then turn to off and remove the key.
Within ten seconds of removing the first key, insert the second valid key and turn to the run position for a maximum of five seconds, then turn to off and remove the key.
To program the third (additional) key, insert the key and turn to the run position within twenty seconds of removing the second key, allow the PATS LED to prove out for three seconds to confirm storage of the additional key, then turn to off and remove the key.
This method can be used to store up to a maximum of 8 ignition keys.
Guest
Posts: n/a
dose any one know how to post ZIP files i have folder with all the TSB'S for the S-type that i got from jaguar GTR. i have them all in a ZIP file and i want to to share them with you all it is about 55 mb. if any one knows how i can post them i will do it for you.
Krikees, that's a big file. I can only store a maximum 15mb file thru my Yahoo/AT&T account. Unless you have your own ftp server connected to the internet somewhere, you won't be able to host this file for anyone to download. You may want to PM a mod or administrator, perhaps they will 'take' the zip file off your hands and host it for you..perhaps linked to an FAQ thread or something.
aholbro1
08-05-2021 05:02 AM
Quebecjag
09-10-2015 06:06 AM
